Text Orient Error
Text Orient Error
Mark_C_123
Text Orient Error
Mark_C_123
I have been getting this error message come up when doing a TORIENT command and the only way I can seem to get past it is by saving closing the dwg and re-opening. It then works for a while and happens again. This also is not drawing specific, happens to alot of different drawing files.
Any ideas on what causes this to happen??
Thanks in advance.. (screen shot attached)
Mark
chriscowgill7373
TORIENT is an express tool.  This is an error that appears every few releases due to coding of the error checking program.  I'm not sure if it is because other custom routines are using the same *error* program or if it is because something got left open ended within the main AutoCAD program.  It is a bug that has been reported, however Express tools are unsupported, so I'm not sure if anything can or will be done about it.  Some people have suggested manually reloading the required express tool files, but I'm not 100% positive that will work in every instance.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2024 on Windows 10
john.vellek
Hi @Mark_C_123,
I believe this is an error in the bug checking but I found these steps that might help:
  1. Use the "Flatten" Command.
  2. Select the desired objects and hit enter.
  3. Verify that the selected objects now have an elevation of "0".
  4. Reuse "TORIENT" command.
John Vellek
john.vellek
Hi @Mark_C_123,
I am checking back to see if my post or @chriscowgill7373's helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
Ive had a similar issue with "TORIENT" command. It fails, along with "MPEDIT", AND perhaps other commands. They simultaneously fail to work until the drawing is re-opened... (not a full AutoCAD reboot).
vinodkl
Can you share the screenshot of the error along  with the AutoCAD version(_ABOUT command) which you are using?
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
