Text on Middle of Line/Polyline
gal.aG8RRW
Message 1 of 8
gal.aG8RRW
i want my text to be in the middle of the line with gap and i cannot find any solution for that.
see picture from Autocad
And in Plant 3D this is Possible
AutoCAD
Plant 3D P&ID with SLINE:
Replies (7)
Message 2 of 8
ВeekeeCZ
Can you use an MTEXT? Mtexts, unlike pain TEXTs, have a Background mask property.
If it's possible in Plant, then it's an enhanced entity. Plain text does not support it unless you want to put a black rectangle (wipeout) behind it.
Message 3 of 8
imadHabash
I suggest to try Background mask as shown below for mtext .
Imad Habash
Message 4 of 8
Kent1Cooper
Use Middle-Center justification, or in the case of plain Text, Middle justification may give you a position you like better, and put the insertion point on the Line/Polyline.  With plain Text, use the TEXTMASK command [read about it in Help for options in size, color, object type].  With Mtext, in the Properties palette you can turn on the Background mask, which also has options.
Kent Cooper, AIA
Message 5 of 8
gal.aG8RRW
First thank you! Helped a lot!
and you have solution for crossing line ?
Message 6 of 8
Kent1Cooper
WIPEOUT
Kent Cooper, AIA
Message 7 of 8
gal.aG8RRW
something more "Automatic" 🙂
and i cannot find how it is working i have lots of Lines it is P&ID
Message 8 of 8
ВeekeeCZ
