Text line weight not consistent
yheLT3G3
Message 1 of 11
yheLT3G3
Hi -
I changed the default font from a shx to ttf in text styles and texts got updated automatically.
However, I'm noticing that text line weight looks inconsistent both in model view and plotted(see screenshot below).
I ran RE command, cleared all text format and matched text properties, but didn't work.
Any idea what's causing the issue here and solutions?
Thank you!
Replies (10)
Message 2 of 11
rkmcswain
Check the "Z" value on those funky looking text objects (should be 0.0), also check to make sure that no font substitution has been applied to those objects.
R.K. McSwain     | CADpanacea | on twitter
Message 3 of 11
imadHabash
can you share with us a CAD dwg sample please for testing ?
Imad Habash
Message 4 of 11
pendean
Community Legend
Community Legend
FLATTEN command will remove the "z" settings and fix the fuzzies.
Message 5 of 11
yheLT3G3
Hi thanks for answering! The FLATTEN command worked for text callouts but caused misalignment in detail bugs and the text still looks different in them...
Message 6 of 11
yheLT3G3
and also all the text callout got exploded to pieces when I ran FLATTEN...
Message 7 of 11
Patchy
Try Command DView, select all, Points, set target to 0,0,0 and camera to 0,0,1
Message 8 of 11
yheLT3G3
Please see attached for the test file. In this file, I ran FLATTEN for some of the callouts and detail bugs but all those callouts got exploded... and the line weight still don't look right in detail bugs..
Message 9 of 11
Kent1Cooper
A possible reason:  .TTF fonts when used at width factors other than 1 can "look" bolder on-screen.  If you are using a Style with a non-1 width factor in the definition, or you have changed the width factor of any Text/Mtext content, you may see that apparent boldness, but in my experience it doesn't plot bolder.
Kent Cooper, AIA
Message 10 of 11
imadHabash
i see that your attribute text has a Width factor = 0.85 , try to change it to 1 .
Imad Habash
Message 11 of 11
pendean
Community Legend
Community Legend
Go back to the file before you ran FLATTEN, set UCS and PLAN to WORLD, then try FLATTEN again.
BTW rotate your view to FRONT or BACK and see those floating annotations yourself, far above the rest of your 2D flat drawing.
