Text is not visible
Text is not visible
Text is not visible
Hi all,
I've just started using AutoCAD for basic geothermal well design. Now when I want to add text as a description, it doesn't show up, only the box is visible when marked. I was using qtext command and turned it off, then regen to refresh drawing, but still no change. Any ideas what is wrong?
Accepted solutions (4)
imadHabash
would you check your text height , please ?
Imad Habash
alex101000
Try to change the text size.
Ed__Jobe
I see that the text height is shown as 2 and the width is nearly 6000. If you are drawing your wells to scale, the text could just be super small. Increase the text height.
Ed
How to post your code.
I realize that the model is super tiny, so how to increase it without making everything from scratch? I assume it would be much easier just to add bigger text that will be visible afterwards
imadHabash
it depends on your drawing scale . either you scale elements OR make your text height readable .
Imad Habash
