I have a problem about values/text of attributes in a block. When I start Autocad, the text in a block is not visible. I have tried several things to solve this problem, but unfortunately it didn't worked. I have tried:
- the command attmode, to set the value of a system to 1
- checked the 'use big font' option and performed a regen
Can someone please tell me how I can solve this problem? I am now busy for hours to search for a solution. I have added a picture to clarify the problem. I have added the text 'this text is not visible to the column to make the problem clear. The whole problem doesn't occur if I restart Autocad for a several times, but this takes a long time.
Thanks in advance!
