Text in block attributes not visible of a block
I have a problem about values/text of attributes in a block. When I start Autocad, the text in a block is not visible. I have tried several things to solve this problem, but unfortunately it didn't worked. I have tried:
- the command attmode, to set the value of a system to 1
- checked the 'use big font' option and performed a regen
Can someone please tell me how I can solve this problem? I am now busy for hours to search for a solution. I have added a picture to clarify the problem. I have added the text 'this text is not visible to the column to make the problem clear. The whole problem doesn't occur if I restart Autocad for a several times, but this takes a long time.
Thanks in advance!
imadHabash
i suggest to try BATTMAN command then Select block then Edit then untic Invisible option and see if nay changes.
if not fix ... would you please attache here one attribute block ( cad dwg file ) to check it for you in our pc ?
Imad Habash
user181
Make sure the layer the text attributes are on isn't frozen or turned off in the drawing.
jggerth
If the attribute in the block definition has an empty default value, there would be nothing to display until you ATTEDIT and put some information in...
Bigfonts are a very very old idea, that has been superseded with Unicode fonts -- please avoid them like the plague they are
