AutoCAD Forum
Text goes black while editing through a viewport
3 REPLIES 3
355 Views, 3 Replies
While I am in paper space, if I go to a viewport to edit text that is in model space the text isn't visible (so I can't see what I am editing).  I can edit fine when I  go to model space.  It just won't let me edit within a viewport.  Please help!
3 REPLIES 3
jayhar
Can you please upload Autocad file in 2013 format to be check
1.Command Shade mode > 2d wire frame
2. Turn off GRAPHICSCONFIG
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
BeKirra
Have you tried to turning off "hardware acceleration"?
GRAPHICSCONFIG is the command.
FYI
"Disable hardware acceleration only if you experiencing graphics issues or have an incompatible video card."
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
pendean
Your AutoCAD variant and year version is...?
Your Windows OS version is...?
Your video card as being used in GRAPHICSCONFIG command is...?
Is the problem in ALL files, or just this one file? Find out.
AutoCAD Inside the Factory
