Text field origin
Text field origin
byoungLW6M5
Text field origin
byoungLW6M5
I am new to the use of fields. I was given a project with drawings spread across into about 50 different subfolders. I am opening up drawings with a sheet set as well as by themselves, containing text fields. Some of them have hash tags, some of the have dashes instead of the real text. How can I tell what drawings or where the field is supposed to be reading from, so I can somehow reconnect it?
VincentSheehan
Could you search or zoom to the object based on the Object ID shown the field expression?
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
paullimapa
checkout this thread which includes Lee Mac's code to take a Field to get the entity:
https://www.theswamp.org/index.php?topic=38694.0
(defun Field->Entity ( en )
  (cond
      (and
        (wcmatch (cdr (assoc 0 (setq en (entget en)))) "TEXT,MTEXT,ATTRIB")
        (setq en (cdr (assoc 360 en)))
        (setq en (dictsearch en "ACAD_FIELD"))
        (setq en (dictsearch (cdr (assoc -1 en)) "TEXT"))
        (setq en (cdr (assoc 331 (entget en))))
      en
Paul Li
IT Specialist
@The Office
TomBeauford
Lee Mac's cleaned up code with a video demo at the bottom of the page.
https://www.lee-mac.com/fieldobjects.html
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
