Text export
Text export
vladop
Advisor Advisor
Message 1 of 19
Text export
vladop
For some time now I have had two problems with exporting text from AutoCAD that I can't solve:
1. When I copy from Attribute Editor
in Notepad I get text with formatting code
2. When I export text (e.g. with ATTOUT) that is displayed in AUTOCAD correctly,
in NOTEPAD for Cyrillic letters I get � and for non-ascii Latin letters \U+ code.
ATTIN import works without problems with all letters.
"Beta: Use Unicode UTF-8 for worldwide language support" is enabled.
Any idea?
Replies (18)
Message 2 of 19
imadHabash
  1.  Try to Paste into Word or excel first (Use “Paste Special → Unformatted Text”, then copy again to note pad to get rid from those formatting codes.
  2. Open the file in Notepad++ or another editor that supports encoding selection
    • Open the exported .txt file in Notepad++.
    • Go to Encoding → Character sets → Cyrillic → (choose your Windows code page, e.g. Windows-1251).
    • Now all Cyrillic and extended Latin letters will display properly.
Imad Habash
Message 3 of 19
vladop
Hi Imad, thanks for the quick reply.
“Paste Special → Unformatted Text” doesn't help.
Changing to Windows-1251 in Notepad++ only fixed Cyrillic characters.
Even the Default encoding for "Save As" in Notepad is UTF-8, not ANSI.
Copying and pasting in Attribute Editor also adds formatting.
A month or two ago I experimented with exporting attributes to SQLite using ObjectARX.
I had the same problems with non-ascii characters.
I probably messed something up then.
If it was a Windows or AutoCAD update someone else would have had the same problem.
Message 4 of 19
vladop
In the meantime I have installed a newer version of AutoCAD and it behaves the same.
This suggests that the problem is in Windows.
Message 5 of 19
vladop
I also had problems in MS Outlook.
I messed up something in Windows.
Message 6 of 19
vladop
Hello again,
in my lisps I used the "open" function with the encoding option in several places, like
(open fname "w" "utf8")
Everything worked for years until the other day when the error: to many arguments started appearing.
I don't remember changing any settings.
I removed the "utf8" and the error went away, but of course I get files with /U+ codes.
That's it, just to share my bad experience with Unicode in ACAD.
Message 7 of 19
paullimapa
not sure when this ever changed but the built-in lisp open function only supports two arguments but not three:
(open filename mode)
https://documentation.help/AutoLISP-Functions/WS1a9193826455f5ff1a32d8d10ebc6b7ccc-698d.htm
Paul Li
IT Specialist
@The Office
Message 8 of 19
vladop
It says here that it has an optional encoding argument:
AutoCAD 2025 Developer and ObjectARX Help | open (AutoLISP) | Autodesk
It worked for years.
Message 9 of 19
vladop
It also says when it was added:
History
AutoCAD 2021
  • filename argument previously accepted an ASCII text string, but now accepts a Unicode text string.
  • encoding argument is newly added.
  • LISPSYS system variable controls which AutoLISP engine is used and the behavior of the function.
    • 0 - ASCII character support and no encoding argument (legacy behavior)
    • 1 or 2 - Unicode character support
Message 10 of 19
paullimapa
Thanks for that because I wasn't aware of that add.
Are you running the latest updates to your 2025 install?
https://help.autodesk.com/view/ACD/2025/ENU/?guid=AUTOCAD_2025_UPDATES
Have you tried installing 2026?
Paul Li
IT Specialist
@The Office
Message 11 of 19
vladop
I tried again in 2023 and now it works. I had to change yesterday because all the functions were giving an error.
Message 12 of 19
paullimapa
so most likely has to do with your 2025 install...
Paul Li
IT Specialist
@The Office
Message 13 of 19
vladop
No, everything happened in the 2023 version.
Message 14 of 19
paullimapa
so what did you mean when you wrote: "...I had to change yesterday..."
Paul Li
IT Specialist
@The Office
Message 15 of 19
vladop
To remove UTF8 argument.
I also remembered that the other day I made a lisp that inserts blocks and there is a problem that the first time I run it after opening a new file I get an error, and then the second time I call the function it works.. It's like something is loading incorrectly. I noticed that VS CODE was reporting that a file was loading, something with - insert dwg event, I forgot exactly what it's called. I think an older version of the file was also mentioned. Maybe this has something to do with it.
Message 16 of 19
vladop
I don't have versions before 2023 installed. They used to be installed but I removed them.
It's probably time to reinstall the entire system.
Message 17 of 19
paullimapa
make sure you have the latest 2023 updates installed:
https://help.autodesk.com/view/ACD/2023/ENU/?guid=AUTOCAD_2023_UPDATES
Paul Li
IT Specialist
@The Office
Message 18 of 19
vladop
The problem with inserting the block could be due to the file "PICK_DWGSDLGEVENTS.LSP".
Message 19 of 19
paullimapa
here's the link to your post in the lisp forum:
OPEN function with UTF option - Autodesk Community
Paul Li
IT Specialist
@The Office
