Text export
Text export
vladop
Text export
vladop
For some time now I have had two problems with exporting text from AutoCAD that I can't solve:
1. When I copy from Attribute Editor
in Notepad I get text with formatting code
2. When I export text (e.g. with ATTOUT) that is displayed in AUTOCAD correctly,
in NOTEPAD for Cyrillic letters I get � and for non-ascii Latin letters \U+ code.
ATTIN import works without problems with all letters.
"Beta: Use Unicode UTF-8 for worldwide language support" is enabled.
Any idea?
imadHabash
  1.  Try to Paste into Word or excel first (Use “Paste Special → Unformatted Text”, then copy again to note pad to get rid from those formatting codes.
  2. Open the file in Notepad++ or another editor that supports encoding selection
    • Open the exported .txt file in Notepad++.
    • Go to Encoding → Character sets → Cyrillic → (choose your Windows code page, e.g. Windows-1251).
    • Now all Cyrillic and extended Latin letters will display properly.
Imad Habash
vladop
Hi Imad, thanks for the quick reply.
“Paste Special → Unformatted Text” doesn't help.
Changing to Windows-1251 in Notepad++ only fixed Cyrillic characters.
Even the Default encoding for "Save As" in Notepad is UTF-8, not ANSI.
Copying and pasting in Attribute Editor also adds formatting.
A month or two ago I experimented with exporting attributes to SQLite using ObjectARX.
I had the same problems with non-ascii characters.
I probably messed something up then.
If it was a Windows or AutoCAD update someone else would have had the same problem.
vladop
In the meantime I have installed a newer version of AutoCAD and it behaves the same.
This suggests that the problem is in Windows.
vladop
I also had problems in MS Outlook.
I messed up something in Windows.
