TEXT Errors
TEXT Errors
Message 1 of 9
TEXT Errors
Recently opening drawings ive been working on for months, it suddenly started displaying the text in model space and on paper space and once printed differently. as a different font etc...
I had the standard font set up as Arial and now everytime i open a new drawing it changes all exisitng text within the drawing to this horrid stick style text and also is a larger size and ruins the drawing and annotations.
also even when i try to create new text and select arial before i start typing anything it still will not display as Arial een tho the text properties says that it is!!!?
very confusing.....? can anyone help?
Attached File PL_06D was the latest revision where the text looke normal. the screen grabs of my CAD now shows how its now decided to start displaying things.
I dearnt try and open any more drawing incase it corrupts the text on them aswell.
cheers,
Replies (8)
Message 2 of 9
m_kingdon
Try the STYLE command and see if anything looks different (font etc)
Mike Kingdon
Civil 3D Zealot
Message 3 of 9
it is showing an erroe for the standard FONT.....??
I assume this means the FONT has dissapeared some how? Do you think this may have happened due to a MS office Upgrade on MS office 365, as this was done on Friday.....?
If so how do i put the FONT file back into the CAD folder on my C:/    ?
Message 4 of 9
It's Odd I think for some reason allot of my FONT files from AutoCAD have been deleted with this new install of MS office.
Here is an example of a full page of BUilding Regs notes that now is completley ruined....!
I dont know what to do I've got Deadlines.....!!! Please someone help
all my drawings are ruined.
Message 5 of 9
Patchy
Roll back the clock.
Hit "Start" lower left corner, type in System Restore and choose earlier date to restore your windows.
Message 6 of 9
Patchy
Check to see if windows fonts got updated.
Hit "Start", type in fonts, check your Arial font
Message 7 of 9
massimo.corradi
I can not tell how/why the fonts were uninstalled.
In any case if you find the font files you just need to right-click them and select install to have them in your system again. You need admin rights for that.
Message 8 of 9
m_kingdon
What is inside your AutoCAD font folder?  Have a look at: C:\Program Files\Autodesk\AutoCAD "your version"\Fonts
Also, go into Options and check the font file path.  Hopefully it might just be a broken link and a system restore won't be needed.
Mike Kingdon
Civil 3D Zealot
Message 9 of 9
Thank everyone!!
all your help was great!
in the end becuase of a recent upgrade to Office 365 on the same PC it deleted Arial Narrow from CAD also.
Just had to get the FONT and put it back in the windows Font folder in the C:/ drive!
all drawings are back to normal!
Many Thanks!
