Text element rotation angle is incorrect
AutoDesk_222
AutoDesk_222
I have this drawing where text elements that are drawn in 0 degree angle, have 270 degree angle under properties. What causes this and how can this be reverted back to normal?
This is probably very simple to fix but was not able to find correct words for solution search.
AutoCAD 2025
chriscowgill7373
Usually it is because the world cs is not the same as the ucs.  In this case rotated -90 degrees.  Try PLAN <enter> World <enter> UCS <enter> World <enter>
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2026 on Windows 11
