Text appearance changes when pasting Excel tables in AutoCAD
I need your help, please. In my office computer, whenever I paste an Excel worksheet to AutoCAD, the text appearance remains the same; but when I tried to do the same in my laptop, the text appears wider and the letters overlap. Does anybody know how to fix this? It also happens whenever I try to update the tables. Here are photos: the first one is the problem, the second one is how it is supposed to look like. Thanks.
BeKirra
Check the fonts used both in Excel and AutoCAD.
Ensure they are the same.
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
up
