temporary files directory is read only or does not exist
Message 1 of 8
When trying to open an AutoCAD file I get the following message:
'All of the possible directories for storing temporary files either do not exist or are read only.  Please correct this situation before running AutoCAD again.'
I have rebooted my computer.
It was working fine yesterday
Replies (7)
Message 2 of 8
chriscowgill7373
Have you tried the suggestions in the AKN article on the subject:
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/When-y...
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2026 on Windows 11
Message 3 of 8
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
 The only fix that I am certain works for all the cases I have encountered, is to create a new user account on your computer with administrator permissions.  Please give this a trial run and let me know the results.
John Vellek
Message 4 of 8
I downloaded and install a 30 day trial edition of AutoCAD and I am getting this same error.  I read the article in the link provided, how do I access the AutoCAD command line?  Also creating a new administrator account for me is a non Starter.
Message 5 of 8
chriscowgill7373
With a drawing in the software open, you will have access to the commandline
Message 6 of 8
Chriscowgill7373 replied:  Re: temporary files directory is read only or does not exist
I get this message when trying to open AutoCad.  The software will not open.
Message 7 of 8
john.vellek
Hi @Anonymous,
Try creating a new Windows User, log on with the new account and the application should launch and run properly.
John Vellek
Message 8 of 8
chriscowgill7373
if your pathing is still set to default, you can open File Explorer and type %temp% in the address bar, which will then open up the temp directory.  If you've changed the paths of the temp directory from default, you would need to locate that revised path to clear its contents.
