AutoCAD Error Aborting
I am receiving this message "FATAL ERROR: Unhandled Access Violation Reading 0x0088 Exception at d2378a72h" when trying to open AutoCAD 2018. What can I do to get my CAD going again? Please help
TheCADnoob
Are you clicking on a file to open AutoCAD or are you opening AutoCAD through the start menu?
CADnoob
Start menu
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
 I assume this has been working properly until recently. What has changed in your environment? A Windows update perhaps? You could take a look and roll back the updates.
You might also look for a more current graphics card driver.
Lastly, you can run AutoCAD using the No Hardware Switch to see if  that helps.
John Vellek
john.vellek
Hi @Anonymous,
I am checking back to see if my post or @TheCADnoob's  helped you with your problem. Please mark a post or posts as accepted solutions if they resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
TheCADnoob
Any word on johns advice of no hardware?
CADnoob
