Technical Font Bold option
roloNCC
roloNCC
In my dimension styles Im trying to make the dimension text bold, but I cant seem to do that. Any idea on how to achieve that without changing the light weight for dims? I just need the text bold as a default.
pendean
Community Legend
Community Legend
DIMSTYLE uses your STYLE settings: looks like you need to create a custom bold-only text style to use, if manually editing the one of few dimensions to be bold in the editor as an override is not an option.
Kent1Cooper
@roloNCC wrote:
... to make the dimension text bold, .... how to achieve that without changing the light weight for dims? ....
With a TrueType font, changing the [I assume you mean] line weight of the Dimension won't have any effect anyway.  If you use a Style that uses a .SHX font, and if you use color-based lineweights in plotting, you can set the color of the Text separately from the other parts, so you can make only the Text bolder, and with many more choices of boldness [i.e. lineweight] than you get with a TTF font that has a bold choice.
Kent Cooper, AIA
Valentin_CAD
@roloNCC ,
Read these links:
Download:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
