Is there a simple tool to do auto-count with prefix, for example AA-1, AA-2, AA-3"
hmm
Select all your Text, change the content to your prefix (use properties palette for Text objects, or use FIND command)
and run Tcount. Use the offered option SUFFIX
done
Sebastian
I do use TCOUNT, first it prompts me to select objects, the second step is to select order (x or y), then (start, increment) <1,1> and then I do have an option to do Overwrite, prefix, suffix, find and replace. but when I type for example AA- (as prefix) and click enter the commend duplicates the numbering without the two letters what I want
Start TCOUNT, press [F1], learn more about Tcount..
The PREFIX/SUFFIX option is for WHERE TO ADD THE NUMBERS! Suffix means, Tcount add the number as suffic to the existing text!
Placement of text- Overwrite/Prefix/Suffix/Find&replace../ <current>: Enter an option or press Enter
Overwrite | Replaces selected text strings with numbers |
Prefix | Adds the number as a prefix to text |
Suffix | Adds the number as a suffix to text |
Find&replace | Replaces a user specified text string with a number |
Because of this, i wrote:
1. Select all your Text, change the content to your prefix (use properties palette for Text objects, or use FIND command)
2. and run Tcount.
3. Use the offered option SUFFIX
Sebastian
PERFECT. IT WORKS!
@Maria_Nowicka_UXMJJH7ABLY6 the old TCOUNT adds numbers, not letters?
If FIND command's wildcards does not work for your needs
https://forums.autodesk.com/t5/autocad-lt-forum/add-prefix-to-existing-text-in-autocad-lt/m-p/103541...
then you need a freebie add-on like https://apps.autodesk.com/ACD/en/Detail/Index?id=8051485828049059617&appLang=en&os=Win32_64
or http://www.lee-mac.com/numinc.html
