TCOUNT with prefix
TCOUNT with prefix
Maria_Nowicka_UXMJJH7ABLY6
Observer Observer
TCOUNT with prefix
Observer
Observer
Is there a simple tool to do auto-count with prefix, for example AA-1, AA-2, AA-3"
imadHabash
Yes , try this one. >> Increment <<
Imad Habash
cadffm
hmm
Select all your Text, change the content to your prefix (use properties palette for Text objects, or use FIND command)
and run Tcount. Use the offered option SUFFIX
done
Sebastian
Observer
Observer
I do use TCOUNT, first it prompts me to select objects, the second step is to select order (x or y), then (start, increment) <1,1> and then I do have an option to do Overwrite, prefix, suffix, find and replace. but when I type for example AA- (as prefix) and click enter the commend duplicates the numbering without the two letters what I want
cadffm
Start TCOUNT, press [F1], learn more about Tcount..
The PREFIX/SUFFIX option is for WHERE TO ADD THE NUMBERS! Suffix means, Tcount add the number as suffic to the existing text!
Placement of text- Overwrite/Prefix/Suffix/Find&replace../ <current>: Enter an option or press Enter
Overwrite Replaces selected text strings with numbers
Prefix Adds the number as a prefix to text
Suffix Adds the number as a suffix to text
Find&replace Replaces a user specified text string with a number
Because of this, i wrote:
1. Select all your Text, change the content to your prefix (use properties palette for Text objects, or use FIND command)
2. and run Tcount.
3. Use the offered option SUFFIX
Sebastian
Observer
Observer
PERFECT. IT WORKS!
pendean
Community Legend
Community Legend
