I have several systems with 4k displays, and resolution scaling set to 200% - essentially making the size of fonts and desktop icons the same size as they would be on a 1080p 28" display. The problem is, when running Autocad 2018, taskbar will not unhide when moving mouse down. This persists on all these systems and still happens after 2019 upgrade.
If I disable resolution scaling by setting it to 100%, then everything works fine, but fonts and icons are so tiny that it is unusable.
Running Windows 10 x64
Solved by osmica8. Go to Solution.
Solved by john.vellek. Go to Solution.
Hi @Anonymous,
I have found that the maximum scaling for AutoCAD is about 125%. If this is not usable, then reduce your resolution slightly to see if that helps.
Hi @Anonymous,
I am checking back to see if my post helped you with your problem or question. Please mark my post as the solution if it resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
There are no problems with autocad scaling at 125, 150 or 200%. On my particular display, 200 is ideal, and the only problem is that taskbar wont unhide when I move my mouse down. It's a very annoying bug that existed in Autocad 2018 and persists in 2019.
Hi @Anonymous,
Thanks for the video! Does the Windows taskbar display properly if you do not auto-hide? What happens if you do not run the AutoCAD window fully maximized? Stretch to nearly maximized and let me know if the taskbar behave differently.
Any update on this? I have the same issue. I've also noticed that when I first open CAD in model space it displays correctly, but as soon as I pan it splits the layout tab side and shortcuts side (at the bottom) into two rows, grabbing useful screen space - image attached
Doesn't happen with me. If i resize autocad window where shortcuts and layout tabs overlap, autocad will split them into two rows, and then as I strech the window back they still stay as two rows, but if I click maximize they go back to one row.
My AutoCAD 2018 was doing that as well, but I didn't notice it as much as the screen jumping around at the same time. On the bottom right hand side, all the way to the right of the shortcuts is a triple horizontal line. If you select that icon, there are a list of several items you can toggle on and off. On the top of mine is coordinates. If you uncheck the coordinates, it seems to solve the issue, both splitting the lines as well as the weird jumpy flickering on my side.
Hope that helps!
Any news on this?
I have 3 monitors and one is different res than the others, and portrait orientation for coding.
This taskbar covering bug has been going on for a long time, and I would not care as much but it causes the command line to undock.
That is like magic to my users so it would be nice to remove the voodoo they are seeing with the command line.
thanks
internal protected virtual unsafe Human() : mostlyHarmless
I'm just here for the Shelties
Why is this shown as an answer to resolve the issue? From what I can see nothing is resolved here and I am also having a similar issue with Revit 2019. It won't let other windows or software supersede it. I have to minimize Revit to see anything behind it.
