- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
When I import an excel sheet into AutoCAD using the >paste special>autocad entities in a table format, the first line is always somewhat ok but the table leaves a leading space in the first column, before the first set of text which has to be manually deleted. With rather large tables I have used data links although a client wants this particular table without the data link. I have tried formatting the excel file text a number of different ways with the same results.
Any help would be appreciated.
