Table Style Plot Style Settings
tim_crouse
tim_crouse
Is there a way to define a different plot style too different parts of a table style?
To clarify, I am using named plot styles
I also have not been able to use table cell backgrounds successfully.  Each time I assign a background to a cell
I get a solid fill that obscures any text.  My target goal is to define a light shading to a table cell that plots as a light gray.
Thanks in Advance
-Tim C.
pendean
Community Legend
Community Legend
@tim_crouse wrote:
...Each time I assign a background to a cell
Can you show us what you mean, and a sample DWG to show us your choices? And what it is you are plotting to as well? We've never had much issue with the on-screen or the print results.
tim_crouse
Here You Go . .
Sample tabe along with Ad-Hoc Table that has defined plot styles.
Plot Style Attached Too
pendean
Community Legend
Community Legend
Thanks for the file @tim_crouse
These are not TABLE objects at all, issues in them are all related to MTEXT widths that are too long. Can you confirm what issue and where it is that you are experiencing?
This is what PREVIEW shows using your plot style table (thanks for sharing that), arrow is pointing to the only TABLE object in that layout
TIA
tim_crouse
I provided the faux tables to illustrate how the plot style displays the text as green and the border as blue.
The table on the right plots the text, border and cell fill all the same color.
I would like the text green and the cell fill to be light gray
tim_crouse
I was able to get the background working.
The key is use a "Normal" plot style.  As such the technique is to create tables with colors pre-defined.
Not as flexible as using named plot styles but progress.
Thanks for your help
-Tim C.
ChicagoLooper
@tim_crouse
There are many STYLES in AutoCAD. Here are a few of them:
  1. Dimension styles
  2. Multi leader styles
  3. Multi line style
  4. Text styles
  5. Point styles
  6.  Plot style
There are also TABLE STYLEs, which you shouldn't overlook. BTW, just like the styles mentioned above, the default OOTB style might be named Standard.
And within a Table Style there's a ROW style.
Image-1Image-1
Image-2Image-2
Image-3Image-3
Understand HOW styles affect a Table Style  and you'll be fine. Ignore them and you'll be relegated to the default styles in your Tables.
Using the default Table is like using the default Standard text style, the default Standard Mleader style, and the  default Dim style. Instead of using the default Table Style, create a new one, customize the new style then name the style using a unique name. Stay away from Standard Table, far far away.
Image-4Image-4
Image-5Image-5
Image-6Image-6
Chicagolooper
