In an AutoCAD table,
B3=67
B4=59
B5=200
B6:
=MAX(0,B3+B4-B5) returns #### when the answer should be 0.
What's strange is that B6 had been formatted as a whole number, but after I entered the formula it changed to text, which might explain the ####, but I can't simply reformat it to a whole number; it's stuck as text.
John F. Uhden
Solved by JTBWorld. Go to Solution.
MAX is not a supported function. Only Average, Sum and Count.
If you find out, let us know. BTW other functions are supported. See
https://www.cadforum.cz/en/qaID.asp?tip=6381
@dbroad Great! I thought I had used a few like round but forgot where I had that list.
