AutoCAD Forum
Table headings are too big
7 REPLIES 7
Message 1 of 8
pvermiglio92
3405 Views, 7 Replies
So in my workplace we work in meters instead of the default milimeters of the autocad workspace, which leads to a lot of workarounds.
One that we cannot seem to avoid is the way autocad handles tables, especially in the table columns and rows headings, since we have to work with a super small text height (from 0.01 to 0.2), the interface seems not to like that kind of scale, which leads to troubles like the headings being so big, it's hard to align the tables properly in the rest of the model. is there any way to reduce their size?
7 REPLIES 7
Message 2 of 8
TheCADnoob
in reply to: pvermiglio92
are you using the latest service pack?
CADnoob
Message 3 of 8
pvermiglio92
in reply to: TheCADnoob
ja, it wasn't installed, but that didn't help at all 😞
Message 4 of 8
TheCADnoob
Select the table and right click and remove any table property overides
CADnoob
Message 5 of 8
pvermiglio92
nope, should i mention that the tables are made by me in my personalized table style in autocad 2016?
Message 6 of 8
nikospur
Can´t say why it happened but I solved it.
1) Create any Table using the Standard Style. In my case, as I also work in meters, it is a style that has huge fonts, etc.
2) Scale that Table to an appropriate size. You will see that the headings scale together with the table.
3) Create a new table style and click on the top left button (Acad 2017) - "Select a Table to Start From:"
4) Make any adjustments you need and save the table style
Any new tables created with this style will display the headings in a scale proportional to your cell sizes.
Hope this helped! As I found no answer I figured this workaround myself
Niko
Message 7 of 8
john.vellek
in reply to: nikospur
Hi @nikospur,
This sounds like a great solution. Can you post some Screenshots or example files? Or, perhaps you can make a Screencast to demonstrate your process?
John Vellek
Message 8 of 8
Thanks to you, I solved the problem of my workmate .. hahaha
Well done.. Smiley Very Happy
AutoCAD Inside the Factory
