Table Fields Wont Update When I Copy Original File
3arizona
Message 1 of 14
3arizona
I have 2 tables that read each other on a template. all field have number values (as an example). when i update text require all other values/fields update after i regen. when i copy the template on the same drawing (all work is on model space) it wont update to new values. is there a setting or system variable to change. Half of the drafter have no problem with the template.
I don't want to change profiles. too many drafter to do that
Replies (13)
Message 2 of 14
john.vellek
HI @3arizona,
To better understand this issue where table fields are not updating, is it possible to attach your template and also make a quick Screencast video that shows your process?
Without seeing this I wonder if it is not better to store the data in a spreadsheet and use a datalink.
John Vellek
Message 3 of 14
3arizona
see attached file.  I don't have video.
Open file and update all numbers in yellow, this works. Issue only happens when copied
*note: A few dafter have no issues.
Message 4 of 14
john.vellek
Hi @3arizona,
It appears that the formula is grabbing the specific cell in the specific table where the formula was originally created. You would either have to change the formula when you paste into a new drawing or I would suggest considering putting it all in one table which should eliminate the problem.
John Vellek
Message 5 of 14
3arizona
i can do that but why does it only happen to a few of us? I can change my profile to another that works but that's not an option. thanks. ill work on
Message 6 of 14
john.vellek
HI @3arizona,
Are you all on exactly identical versions of AutoCAD?  Does it behave differently if it is saved as a block and inserted into the drawing as opposed to using copy/paste?
John Vellek
Message 7 of 14
3arizona
we are all on 2018.  i remember why i have 2 tables, the top is on a no plot layer.  I cant find a way to have a portion of the table on a no plot layer.
Message 8 of 14
john.vellek
Hi @3arizona,
You could set the pen color to 255,255,255 for the top part of the table. Did you try the INSERT method to see if behaves differently?
John Vellek
Message 9 of 14
3arizona
templates are set in Model Spade as 3 rows of 5 and copy as needed. no need to insert everything on a dwt file
Message 10 of 14
john.vellek
Hi @3arizona
I am sorry if I was not clear. I am suggesting that you make the table(s) a block and insert them instead of having them in a template file.
John Vellek
Message 11 of 14
3arizona
i'll try and update you tomorrow?
Message 12 of 14
3arizona
John,
Fields behave the same when copied on inset. It has to be a system variable. i checked Fields under OPTIONS/Users Preferences and it's all good.
thanks for your time
Message 13 of 14
john.vellek
Hi @3arizona,
Can you make a Screencast showing how this works for those lucky users?  I would like to make sure that I am doing the same thing you are.
John Vellek
Message 14 of 14
3arizona
JOHN,
I could not find a solution to the the 2 tables reading each other after a copy was made. i erased all formulas and reinserted them with no luck.  i took your advice and combined both tables to one and used 252,252,252 color, for the no plot text.
pretty odd that some of us had no issues with the original setup.
thanks
