As far as I can tell and recall, there is no variable for the text style you would select in the MLEADER typed command nor within the MLEADER Style Dialog. Instead what I have found is that the text style is kind-of "ported" through the dialog via the "Style" command ("st" as alias and also the Text Style Dialog).
Thus, what you are dealing with is the necessity to alter the particular text style that is assigned to your MLEADERS. If you know that the "Standard" text style is assigned, or any other style particular to your office, then you could simply alter that Text Style "en mass" using a script or LISP routine.
The way I understand the post is that you wanted to narrow down to the usage of the style in the MLEADER variables via script. If instead your query is creating a script then let us know if scipting or LISP help is what you want help with.
I think I have identified where you need to target and would help additionally with the routine/s if needed?
Cheers,
Blaine
Blaine Young
Senior Engineering Technician, US Army
