Symbols in paperspace "falling through" the viewport
so I am trying to put some symbols on my drawing in the paperspace, arrows and fire safety symbols and stuff like that. This usually works great but not with this particular drawing - when I put symbols they kind of fall through under the floor plan which is in my modell space. Does anyone have any idea why this could be happening? I tried making a completely new viewport but this didnt work.
RobDraw
It sounds like the viewport is active but without an example, it's just a guess.
Rob
Valentin_CAD
@Anonymous ,
Like @RobDraw mentioned, you may be working within the viewport.
Check the correct workspace (Paper Space) is active and not in the viewport - see image below:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Alfred.NESWADBA
>> in my modell space
I guess this switch is set incorrect, please, inside the plot-dialog, make sure the checkbox for "Plot paperspace last" is activated:
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
RobDraw
Solved, really? What's the solution?
Rob
Valentin_CAD
@Anonymous ,
I think you mean if the "issue got solved??", and it has yet to receive a solution check, so no.
Also, make sure you use the quote symbol when quoting others - see image below.
Emilio Valentin
