Switching units mid drawing
Message 1 of 9
I need to be able to show the same drawing in both inches and mm. Is it possible to change the units back and forth after a drawing is completed?
Replies (8)
Message 2 of 9
natasha.l
Hello @Anonymous,
I wouldn't recommend going back & forth changing the drawing units. If you have blocks & templates etc. it will make it a more manual process.
You can have an imperial (inches) version & a metric (mm) version of the drawing. Maybe xref to link them to one another.
Take a look at this video on how to change the units of a AutoCAD file.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Message 3 of 9
GrantsPirate
I would stay in the units you started with and just add alternate units in your dimension style(s).  Go into edit the dim style (DIMSTYLE) and look for the Alternate Units tab.  Select the Display alternate units box, then adjust the options for what your alternate dims would be.  Now the dimensions will show two units, example would be Imperial / metric mm.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Message 4 of 9
dgorsman
Yeah, changing units in AutoCAD just changes the name of the unit not actual physical values i.e. there's no conversion of values between 1" and 25.4 mm.  It will change between 1" and 1 mm.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Message 5 of 9
pendean
Community Legend
Community Legend
why? explain your final intent/result, no one ever really does that. There is probably something else you can do instead.
Message 6 of 9
I do shop drawings for a kitchen showroom located in Los Angeles but the kitchens are made in Spain. I need to be able to show the same plans and elevations in both decimal and inches.
Message 7 of 9
S.Faris
Use the Alternate units and adjust the "Multiplier for Alt units" as required and also add a suffix for the Unit symbol. Refer to the attached DWG and check the "Alternate Units" set in the Dimension style applied, for reference.
SALMANUL FARIS
Message 8 of 9
pendean
Community Legend
Community Legend
The AutoCAD-by-design approach is the one noted in reply #7 is how we all do it when working with overseas + local clients on the same project https://forums.autodesk.com/t5/autocad-forum/switching-units-mid-drawing/m-p/9239449#M1005419
Message 9 of 9
Thank You Kent, that sounds like the perfect solution.
