Sweeping command issue
Message 1 of 11
I am busy designing a Haul road under ground and my sweeping command is not sweeping correctly .
My path is a 3d polyline.
Please Help...
File is attached
Replies (10)
Message 2 of 11
Patchy
Sweep and twist it 90 degrees
Message 3 of 11
how did you do this? i tried and failed.
Message 4 of 11
see snips attached
Message 5 of 11
Patchy
That was how I did it, after sweep command, I chose twist and used 90 degrees, it took about 30 seconds to complete that task.
Try the red 3dpoly and see if it works for you.
Message 6 of 11
what coords did you use.
Please see snipit
Could you make a vid by any chance?
Message 7 of 11
Patchy
I'm using your drawing, copy the path and the section of the tunnel, I always leave the original alone.
I cannot make videos, but you can see all the commands I used, nothing special.
Message 8 of 11
thanks man. does not want to work.
What version are you using?
Message 9 of 11
Patchy
2008 Autocad
Message 10 of 11
j.palmeL29YX
@Patchyschrieb:
2008 Autocad
In newer AutoCAD versions this does not work correct anymore.
Here a screencast how I got an approximated solution in ACAD 2018:
https://autode.sk/2KBiALx
But attention: A good value for the twisting you must find by experimenting. A value a bit smaller than 105° (I only did guess) can give a better result. A correct solution is not possible this way. (This also applies to the solution shown above).
cadder
Jürgen Palme
Message 11 of 11
j.palmeL29YX
A better result you will get this way:
Put some sections (the tunnel contour) along the spline. This I din't show in the screencast. Then use the loft command, from one section to the next next next ... Then choose the Path option and select the Spline. (Now you have to wait some seconds - voila)
https://autode.sk/2jutcPL
HTH
cadder
Jürgen Palme
