Sweeping Closed Loop
Hey All,
I'm trying to sweep a simple zigzag pattern around a rectangle (for a duct). It works if the rectangle isn't closed (one side missing) but I can not get this to work otherwise.
Can someone please explain why this happens? I've attached the .dwg. Using AutoCAD 2018.
Thanks for the help.
So this is the best I can get (explode the rectangle and join only three lines).
Erense
I would suggest creating a non closed polyline where there is a very small gap between the start and the end point.
If you put the start/end at the middle of the bottom then the 'line' will be there.
This does create the image you want.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Edwin Rense
Cadac Group AEC BV
Supporting Consultant AEC
Cadac Group .
