Sweeped objects do not show in other programs
Hello!
I opened my AutoCAD 3D model with 3DMax and Sketchup, but any sweeped objects would not appear.
What might the problem be?
AutoCAD and it's vertical products has some unique objects that it calls Proxy object.
So 3Ds Max does not support those objects.
To appear them, You need to download Object Enabler.
To use in Sketch-up, Try use command -EXPORTTOAUTOCAD in AutoCAD.
That didn't work out; the elements still do not appear when I import to sketchup 😕
If you can upload your drawing, Then We may help you quickly.
Here's the file
Sketch-up can't read Surface entity. You need to convert it to 3D face.
I upload a fixed drawing.
This Article will help you about importing DWG.
In 3Ds Max, Import -> AutoCAD drawing, Can import your the original drawing.
This fixed it. Thanks a lot!
