Sweeped objects do not show in other programs
No aplicable
Hello!
I opened my AutoCAD 3D model with 3DMax and Sketchup, but any sweeped objects would not appear.
What might the problem be?
0 Me gusta
Responder
Soluciones aceptadas (1)
352 Vistas
6 Respuestas
Respuestas (6)
No aplicable
AutoCAD and it's vertical products has some unique objects that it calls Proxy object.
So 3Ds Max does not support those objects.
To appear them, You need to download Object Enabler.
To use in Sketch-up, Try use command -EXPORTTOAUTOCAD in AutoCAD.
0 Me gusta
No aplicable
That didn't work out; the elements still do not appear when I import to sketchup :cara_asombrada:
0 Me gusta
No aplicable
If you can upload your drawing, Then We may help you quickly.
0 Me gusta
No aplicable
Here's the file
0 Me gusta
No aplicable
Solución aceptada
Sketch-up can't read Surface entity. You need to convert it to 3D face.
I upload a fixed drawing.
This Article will help you about importing DWG.
In 3Ds Max, Import -> AutoCAD drawing, Can import your the original drawing.
No aplicable
This fixed it. Thanks a lot!
0 Me gusta
