Hello all,
First let me start of by saying that I am relatively new to Autocad so any help is appreciated.
I am trying to draw a coil made out of rectangular wire.
I started by making a helix, I then made a line where I needed the helix to stop in order for both "ends" to be facing the same direction. I then used trim to make a break at the point where the helix and line intersected and deleted the line and unneeded portion of the helix. I then made two more lines to extend each "end" of the helix in order to make "wings" or "leads" off of the coil. I lined everything up correctly and used join to make one object.
Next I made a rectangle, representing the cross section of the rectangular wire the coil is meant to be made of. I used 3drotate to position the rectangle so as it was perpendicular to the end of the leads off the end of the coil. After that I used sweep to make my coil and changed my view to shaded.
It was then that I noticed two problems, the first much more severe than the second.
First, at the top of my coil the rectangle (wire) is positioned correctly and everything starts off good, but as the coil descends the rectangle/wire begins to rotate and has a substantial rotation/bend by the end of the coil.
Second, each of the leads/wings that I added to the coil have a visible line both in wireframe and shaded view where they meet the original coil.
I will attach a copy of my file for reference In case I was not clear in my explanation.
Where did I make a mistake? What should I do differently to remedy these problems?
Thank you for any help or advice.
