SWEEP. ALIGNMENT and SCALE. model operation error: can't locate profile on rail.
Message 1 of 9
Hello!
Please help! I'm using Autocad 2017.
I cannot seem to get SWEEP to work property when I try to use both ALIGNMENT and SCALE options within the sweep command.
Here's what's happening:
Screen Shot 2017-06-19 at 9.46.17 PM.pngScreen Shot 2017-06-19 at 9.46.36 PM.pngScreen Shot 2017-06-19 at 9.47.02 PM.pngScreen Shot 2017-06-19 at 9.47.32 PM.pngScreen Shot 2017-06-19 at 9.57.21 PM.png
So basically you see me try SWEEP with alignment only, and it works, Then SWEEP with scale only which works, and then I try both together and get the following error:
ALTERNATIVELY, if someone knows of a simple way to get from the larger cylinder to the smaller cylinder, I would also be interested in that. I just want to connect the larger one , taper down to the smaller one. I figure SWEEP is the way to go. Just don't understand why it works individually but can't use both SCALE and ALIGNMENT together.
Thank you.
Replies (8)
Message 2 of 9
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
I haven't ever tried Alignment and Scale in a sweep. If I were to connect the two pipes I would use a loft between the two.
When I did this with a sweep, I was able to use alignment and scale together.
Can you attach a sample of your drawing so i can see if I am able to perform this in it?
John Vellek
Message 3 of 9
Thanks John.
How would I go about using Loft to connect the two cylinders? I'll give it a shot. It's quite possible I am doing things the hard way!
Message 4 of 9
Thanks John.
Message 5 of 9
john.vellek
Hi @Anonymous (love the name BTW)
I made a quick video to show the way I used loft to join the cylinders. I basically create a circle at the end of each cylinder, type LOFT, select the two circles and the connection is created.
John Vellek
Message 6 of 9
parkr4st
There is the command XEDGES which will find those circles for the loft.  Removes the chance for drawing errors when drawing the circles.
dave
Message 7 of 9
john.vellek
Hi @parkr4st,
Thanks for that! Nice addition (XEDGES) to help the OP.
John Vellek
Message 8 of 9
JOHN !
You are a genius.
Thank you so much!
Message 9 of 9
DAVE!
EXCELLENT !
makes what I am doing 20x faster. Thank you!
