svg to dwg?
svg to dwg?
svg to dwg?
Does anyone know if I can convert a svg file to dwg? free if possible?
If you were to consider third party software, ToolPac 11.0 at
http://www.dotsoft.com/toolpac.htm contains a SVG Import.
> free if possible?
Do you work for a certified charity organization?
Terry
Nice Sales Manner!
Ace-TW
If you can install the free software Inkscape (http://inkscape.org/) then you can convert your svg to a pdf file (as it can saves as pdf).
You can then use anonline website http://www.pdftodxf.com/ to convert pdf to dxf...
Or alternatively, you can find also free-to-try programs like "Any PDF to DWG Converter" (or others) to do the same thing. After that, autocad can open dxf and save as dwg...
Best of luck!
johnthoreson
Inkscape will save directly to dxf under the Save As command, saving a step in the coversion.
