Survey Data after plotting in Autocad 2D gives very small lengths and areas
Message 1 of 11
recently i did a survey and after importing the data from excel to autocad 2D, area is far less.
i had surveyed a area of 11000 sq feet and after importing the data from excel to autocad it shows a area of just 18 square feet .
i have tried setting my units and dim. style
but nothing helps .
Please Help ASAP.
Replies (10)
Message 2 of 11
imadHabash
Since we don't have your drawing , i suggest to :
  • check your INSUNITS system variable .
  • check -DWGUNITS all settings .
Imad Habash
Message 3 of 11
Alfred.NESWADBA
How did you do that, which units have you had in Excel and which in AutoCAD
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 4 of 11
sir
i have already set that . the unit of the data i have taken through TS
survey was in meters .
and i tried to import that to autocad by putting UNITS to "engineering"
and precision to 0'-0".
and again in DIMSTYLE i changed units to engineering
and after importing using "sw dtm " when i measure lengths it measures 7" (
7 inch) only.
and a little higher and whole area gives very little area.
please sir suggest me to correctly import and if possible help me import
the data in feets as i feel comfortable in working with feets.
Message 5 of 11
hii sir ,
sir units in my TS was set to meters and soo should be the units in excel.
and i at first set up UNITS in autocad to "engineering" and precision 0'-0"
and inches
and in DIMSTYLE too i set units to engineering inches
and when i import from excel using SW DTM , the length measures just 6"/7"
( in inches)
i dnt knw if i should be importing the data in same units as i have taken
in TS.
and is there any method optional tht i could import data in feets in
autocad.
help me sir
thank you .
Message 6 of 11
Alfred.NESWADBA
I don't know this software and so I don't know if that transforms data between different coordinate systems or different units. But when it's just an insert of object at the location defined in the XLS (in Meter) then your DWG-file should also be set to Meter as units.
When you need it later in Feet or Inch (and as long as you are not dependent on geographic coordinate systems) you can always use command _SCALE to scale your geometry from Meter to the units you want to have (and change _UNITS to this new setting too).
- alfred -
Alfred NESWADBA
Message 7 of 11
АлексЮстасу
When importing, I don 't think units are recalculated.
Therefore, it is necessary either to recalculate the values from meters to feet in the source (in Excel or the like), or to use the Scale command with the required factor (3.280839895 or the like) with the base point of 0,0.
wrote faster! 😀
-- Alexander, private person, pacifist, english only with translator 🙂 --
Object-modeling _ odclass-odedit.com _ Help
Message 8 of 11
Are you using a State and Plane projection or Long Lat?
Long lat will import exactly as you describe. State and Plane projection will import at correct scale, whether that be Meters, Feet, Parsecs, etc.
Message 9 of 11
sorry sir i didn't get what u said .
please explain me sir how can i know if it is in state and plain projection of in Lat .
i have not heard about it before
Thank you for your time sir.
Message 10 of 11
АлексЮстасу
You have a plained orthogonal projection, as you wrote that units are meters.
If you scale the entire drawing (as advised you) with a factor of feet relative to the base point of 0,0 - you will have both coordinates and dimensions corresponding to feet.
Message 11 of 11
АлексЮстасу
You can convert a drawing to other units with coordinate and distance changes using -DWGUNITS.
