Surface Texture Symbol
Message 1 of 14
Hi, I'm trying to produce a surface texture symbol and I've found online how to make one but can't seem to find where it says to go.  It gives directions as follows:
  1. Click the Annotate tab > Symbols panel > Surface Texture.
I am on AutoCAD 2016 and I see the Annotate tab but cannot find this symbols panel or anything related to it.  Please help.
Replies (13)
Message 2 of 14
john.vellek
Hi kpicton,
Welcome to the Forums!
I am not sure what you are really trying to do here. Can you describe or show me an example?
As far as the missing Symbols Panel, I am guessing this might be from one of the vertical products as opposed to the standard AutoCAD 2016. Mine does not have this panel either.
John Vellek
Message 3 of 14
All I'm trying to do is produce this symbol so I can use it.  Here is an example of what it looks like with all it can describe: http://www.engineersedge.com/imagefiles/manufacturing/iso-surface-roughness.gif
If you want more examples just google 'surface texture symbol' and go to images and you'll see a ton of examples
Message 4 of 14
pendean
Community Legend
Community Legend
Three is no SYMBOLS panel in the Annotate Tab in plain AutoCAD: your instructions are from another variant of AutoCAD most likely. Find out or share the link if you can't tell.
Otherwise you want to draw it with Plines or find it in a custom font file or a custom SHX shape file, there is nothing in the core plain AutoCAD program to replicate your image.
Message 5 of 14
Sorry probably should have included this in the first post but here's the link I was trying to get it from.  https://knowledge.autodesk.com/support/autocad-mechanical/learn-explore/caas/CloudHelp/cloudhelp/201...
So you're saying with my version of autocad that creating that symbol is not possible?
I attached a screenshot of my AutoCAD Annotate Tab.
Message 6 of 14
Your screenshot is plain AutoCAD.  Your link refers to AutoCAD Mechanical.  Two different products.  Your version doesn't have all of what's in the Mech variant.
Message 7 of 14
Thanks for sorting that out.  So there's no way to produce that symbol unless I just manually draw it correct?
Message 8 of 14
john.vellek
Hi kpicton,
I suggest that you create the linework and add attributes. Convert it all to a block and then you can add it to a symbol library and maybe even a menu tab or  Tool Palette.
I would be happy to point you to additional resources for any or all of these steps if you like.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
Message 9 of 14
john.vellek
HI kpicton,
I am checking back to see if my post helped you with your problem. Please add a post with your results so other Forum users can benefit.
John Vellek
Message 10 of 14
Hey there,
  Thanks for following up.  It was just for a school assignment, not work related but now I'm aware that I can make this symbol and save it for future use if needed.  I did not do that but just drew it one time as I only needed it once.  I appreciate the feedback given and the clear steps with links to describe each step.
Thanks again
Message 11 of 14
john.vellek
Hi @Anonymous,
Glad to hear that your were able to work through the Symbol drawing. I’ve just accepted the response to your post (link here) as a solution so that others can benefit from the information.
In the future, please click on the ‘Accept as Solution’ button if/when relevant. Please feel free to let me know if you have any questions or concerns!
John Vellek
Message 12 of 14
greg.youngCXLLN
"Accept as a Solution" ? How about "Accept as a Work Around"! This program is expensive rubbish
Message 13 of 14
PMZUPANC
I can't believe tha plain AutoCad does not include the Symbols panel. It should be included by default.
Message 14 of 14
pendean
Community Legend
Community Legend
You are just using the wrong variant of AutoCAD: there is never going to be one installation with everything in place ready for anyone to use on a whim.
Install the correct variant of AutoCAD that you need, AutoCAD subscriptions (and STUDENT versions) give you the ability to install and use all the ones discussed above. Do so now:
https://manage.autodesk.com/products
