Message 1 of 12
09:36 AM
I am using the Navisworks API to create a plugin that performs certain tasks with mtext objects. However, the MTEXT properties in Navisworks do not contain the Contents property that is in AutoCad.
For example, here is a picture of the model item properties in AutoCad. It shows that the Contents are equal to "1138".
Here is the same model item in Navisworks. I've used a plugin that shows all of the properties for a model item so you can see that the contents aren't transferred when the .dwg imports into Navisworks.
Is there something I can from the AutoCad side to make this work? Thanks!
