I am trying to add a close 2D polyline to a surface as a boundary, but when I do so nothing happens. I do not event receive errors. Has anyone ever had this issue? Your help is much appreciated.
Solved by john.vellek. Go to Solution.
Hi @Anonymous,
Does this work if you use a 3dpoly? Does your UCS match that of the surface?
Using a 3D polyline worked! I have used 2D polylines in the past as boundaries. I am not sure why it was not working this time. Thanks.
