Superhatch -> pat file
Crass
Crass
Is there a way to convert or export a hatch created in Superhatch (Express Tools) as a .pat file? Also are there generally any more 21st century methods or tools for creating custom hatches from scratch? Thank you
AutoCAD 2018/2021
AutoCAD Civil 3D 2021
rkmcswain
No. SuperHatch exists because AutoCAD Hatch patterns do not support the type of objects that SuperHatch does.
To your last Q, someone may have already made what you need.  That's always easier than starting from scratch.
R.K. McSwain     | CADpanacea | on twitter
ChicagoLooper
Are you able to execute superhatch?  Can you post an image of your superhatch  inside a boundary?
Chicagolooper
Crass
In this case it's super simple and similar to a lot of standard hatches, but it would just be nice to draw something exactly the way you want it and use it as a hatch, specifically for paving materials and patterns. The one below is a 16"x32" stone in a running bond. For us it's often important to have a hatch actually match the size and pattern of the actual material rather than just being representational.  Superhatch is fine but when extents change or if you want to change origin it's a pain. Thanks
AutoCAD 2018/2021
pendean
Community Legend
Community Legend
Grab this freebie to create your own simple custom hatch pattern like that http://www.cadhatch.com/hatch-pattern-generator/4588167700
Crass
Thanks! Looks like a good tool
AutoCAD 2018/2021
ChicagoLooper
Don't get wrong but if you know how to use it's not a pain if extents change.
BTW, hatch is always representational. I think what you want is a material or surface a rendered appearance. After all, real concrete doesn't have triangles in it like the hatch does and real 'Earth' which is soil, doesn't look like vertical and horizontal lines.
Chicagolooper
