Superhatch command not working Autocad 2016
I deleted all the *.fas, and *.lsp files as suggested on another post, and reinstalled Express tools again, but the Superhatch command still does not work
Alfred.NESWADBA
In all folders of AutoCAD? Or which files did you delete?
BTW: deleting program files instead of uninstalling results in defect installations, especially not just one specific file that will be exchanged maybe, writing "deleted all FAS and LISP files" sounds critical for me.
I would run a repair-installation of AutoCAD (which version do you have), then try ExpressTools and let us know, if it's working then.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
I tried the repair option, & got an error (screen shot attached), obviously
the *lsp files are missing
What now??
Alfred.NESWADBA
Sorry, no screenshot attached (please don't use your mail system when you want to attach files, answer in the forum to the thread using your Internet Browser).
- alfred -
Alfred NESWADBA
Hi Alfred, I ahave attched the screenshot error
Alfred.NESWADBA
You have not only deleted the files from your program folder, but also from your installation media ... worse than I though above, sorry.
You need to
  • download the installation package from Autodesk (https://manage.autodesk.com) ==> download the installation file(s) using "Browser Download".
  • Then erase the folder C:\Autodesk\AutoCAD_2016_English_Win_64bit_dlm
  • Then uninstall AutoCAD from your system
  • Then start the downloaded file with right-click ==> start as administrator and install AutoCAD again (don't forget to check the installation of the ExpressTools
- alfred -
Alfred NESWADBA
