I suggest don't try to jamb it all into too few folders. You can always get rid of extra ones if you don't use them.
In a short explanation we have 3 folder trees that relate to just the drawing aspect. One for what we call admin. It only contains pdf and job site pictures, spec sheets etc. It's so other people can get the pdf of the dwg but they don't mistakenly mess with a dwg file. Second we have where we store the dwgs. Broken down by year then project, basically the same as admin but in a different place so no confusion. Under the drawing folder in there we have it split into drawing parts. Like a master x-ref folder for that drawing, base drawings, dwgs from outside sources (surveys, structural, etc,) Third we have a folder with all the cad manager stuff in it. It's broken down into like blocks, linetype, standard dwg, templates, a folder with lisp files, title blocks, palette files, etc. I like to create a folder with each cad persons name too. Like Nick_temp. Say I take a snip it or make a copy of a dwg to try a lisp I never used to make sure it doesn't break the drawing, I'll throw it in there. It keeps people from saving things they either will forget about or only use once all in random places. It's the one folder I don't care if people clutter up because only they will use it.
Nick DiPietro
Cad Manager/Monkey
