I remember asking about such a thing, but there used to be an actual button on the main page, linking you directly to it. I don't see that button anymore, so thanks for the link!!
While I have your attention, and you being in the know as you are, let me run the idea by you to see what you think, or perhaps you can tell me if it already exists.
I currently work for a windows company (large see-thru glass objects, not a Microsoft venture), drawing lots of large rectangles (for the most part), so the majority of what I draw are large visual area objects (several to many feet in size), but the framing is only 2", and the details on the framing only fractions of an inch. So my thought, to save constantly zooming in and out at every intersecting point of the frame, to insure I'm snapping to the correct point instead of the point 1/4" away from it, is to show a zoomed pop-up box in one corner of the screen, let's say approximately 1"x1" or whatever (also depending on monitor size, obviously) that shows which snap point is being highlighted for selection. And as I move the mouse pointer, it would act just as if I had zoomed in, and would subsequently move to highlight the next snap point. The box would then disappear once the need to show a snap point was no longer required. Kind of like having a model viewport whose visual content showed a 1"x1" box around the crosshair.
Thoughts...?
