Suggestion! Mid of 2 points
Here is a suggestion... you know how when there is a shape your curson can clip onto the center of the shape...?
And when you hover over an edge and then another edge autocad provides for an intersection of their perpedicular lines...
i would like to hover over 2 points and then have my curson clip on the midpoint of those two points without having to actually make a line.
[The subject line of this post has been edited for clarity by cheryl.buck]
3wood
You can type MTP to get the middle point of 2 points.
imadHabash
As mentioned above .. you can use MTP (Command Modifier) . >> Click <<
Imad Habash
peterm
Or you can use shift and right click:
RobDraw
OSnap Tracking
Rob
RobDraw
Did you look into OSnap Tracking for your first suggestion?
It is quite the powerful tool that builds on plain old object snaps. It's also quite customizable with user level settings.
Rob
