suggestion list when you type a command
Message 1 of 15
my input search dialog box doesn't appear in the left corner of the command line. wht to do to make this appear in the left corner. now it appears in the right corner. to be more exact i refer to the suggestion list that appears when you type the first letters of a command
Replies (14)
Message 2 of 15
imadHabash
would you try to Reset Settings to Default from Windows icon > All Programs > AutoDesk > AutoCAD 2015 .
Imad Habash
Message 3 of 15
i tried. no change
Message 4 of 15
imadHabash
what about latest Service Pack ?
Imad Habash
Message 5 of 15
i'll search for it. i'll tell you if anything changed after installation
Message 6 of 15
no change
Message 7 of 15
ВeekeeCZ
Dock your commandline. Too many issues connected with this floating version.
Message 8 of 15
no change
Message 10 of 15
john.vellek
Hi @Anonymous,
I am sorry that you are experiencing this issue.
I suggest trying the following to see if the error will be corrected:
  • Turn off Hardware Acceleration in GRAPHICSCONFIG
  • Remove any customization or add-ins
  • Perform a program Repair in the Windows>Program control panel
  • Create a new user account (administrator) and logon to AutoCAD to see if the issue persists. If not, this indicates some corruption in your user profile
  • Reset Settings to Default and then don't customize or install add-ins until you can see if the problem is still present or gone
  • If none of these steps work I suggest a clean uninstall and reinstall.
John Vellek
Message 11 of 15
creating new user account resolved my problem. please tell me what to do next. how to do a clean install? what means that i have some corruption to the account i use?
Message 12 of 15
john.vellek
Hi @Anonymous,
I am glad that the new user account worked.  Here is an article I found on the web that might help with the profiles.
If you have a domain network account, you can also save all your bad profile docs onto your network, delete the account and folders off the workstation and then add the account back onto it.
John Vellek
Message 13 of 15
what do you mean when you say bad profile docs? how do i know which are bad profile docs?
Message 14 of 15
john.vellek
Hi @Anonymous,
I apologize for not being clear. I meant any docs or files that you have saved in the older profile. Removing the profile and folders from the computer would also erase the files.
John Vellek
Message 15 of 15
creating a new user account is not a good idea. for me problems appeared after creating new user account like long delay after right clicking. the best solution is reinstalling windows and reinstalling autocad
