Suggest: Let Divide start any point which we want, such as 60 degree.
kimhowoon
Message 1 of 10
kimhowoon
I posted "Divide a circle with specific starting point (for example : top (90 degree, at y axis)."
at that time 90 degree was good enough to me.
So I accept : Solved: Re: Divide a circle with specific starting point (for example : top (90 degree, at y axis). ...
But original intention of mine was any specific starting point not just 90 degree, for example 60 degree.
My suggestion: when ask number
Default(i.e. number input):  start at the start of the object
additional option command P: select Point of first Divide point.
Replies (9)
Message 2 of 10
Kent1Cooper
@kimhowoon wrote:
.... original intention of mine was any specific starting point not just 90 degree, for example 60 degree. ....
Which you can of course do in the same SNAPANG way.  But no one here can do anything about your suggestion -- we're just other Users like you, with light oversight by Autodesk people who are not the ones you want to reach.  Go to the >Product Feedback Page<.
EDIT:   So would you be interested in the same idea for other object types?  Divide a Line, but starting [x] drawing units in from the start?  For that, you may be able to use the DIV+ command in DivideMeasurePlus.lsp, >here<.  It has an option to inset [from both ends] the end-most locations for what it places.  [It can do the same for a Circle, but by distance along it, not by angle, and again, inset from the 0° quadrant in both directions:
so it's not quite what you're talking about.]
Kent Cooper, AIA
Message 3 of 10
kimhowoon
You can do many things about my suggestion, such as adding more command options which can operate more smoothly, lower errors, etc.
Basically, I just want to check other's thoughts about my suggestion  before feedback page.
Message 4 of 10
RSomppi
I'd suggest using the power of AutoCAD's customization tools to make your own command. Requesting a new feature is a waiting game at best. A request does not guarantee implementation.
Message 5 of 10
Kent1Cooper
@kimhowoon wrote:
[[ Kent1cooper wrote:  But no one here can do anything about your suggestion -- we're just other Users like you, with light oversight by Autodesk people who are not the ones you want to reach. Go to the >Product Feedback Page<. ]]
And who, exactly, do you mean by "You" in that?  You can't be talking about altering the operation of the DIVIDE command itself, unless you think "we" are Autodesk programmers [read my Message again].  Over in the Customization Forum, many of "us" would be capable of creating a custom command definition that might be able to operate as you prefer, or better yet, guiding your attempts if you try it yourself as @RSomppi suggests in Message 4.  If that's what you're talking about, create a topic over there, where there are more other Users interested in pursuing such things.
Kent Cooper, AIA
Message 6 of 10
kimhowoon
everyone
suggesting to this thread does not require anything.
Message 7 of 10
kimhowoon
Actually, it can be waited
just suggestion not emergency call.
Message 8 of 10
RobDraw
So, how are you accomplishing the desired task?
Rob
Message 9 of 10
kimhowoon
You mean this?
Message 10 of 10
RobDraw
Yes. There are a number of ways to customize that.
Rob
