Subtract an Imported Model
calebUYG4X
Observer Observer
calebUYG4X
Observer
Observer
I imported a .dwg file into my current project as an XREF.  I then inserted it so it is no longer shown as an XREF but as part of the main drawing.
I am trying to subtract the imported 3D object from an object in the current project.  When I attempt to do this using the subtract tool, it does not work.  I am guessing it has something to do with the way I imported the object?
Does anyone have any ideas as to why I cannot subtract the imported object from the object in the main drawing?
If needed I can attach the DWG files here.
Thanks.
Patchy
If you save it to version 2014 or older I'll take a look.
calebUYG4X
Observer
Observer
Sure thing.  See attached.
I also attached the newest version incase others might like that.
"Screw" is the dwg I imported (if needed), and "TC Gear" is the main project (the one in which I am trying to subtract).
And here is a video of what I am trying to do and what happens:
https://youtu.be/e6mSvr7N958
Thanks again.
P.S. Sorry for the disorganization and the bad design practices, I'm still learning.
calebUYG4X
Observer
Observer
And here is the "Screw" file in 2013 format.  It would only let me attach 3 files per post.
Patchy
The problem:
The screw is a block, you need to explode it, then you will see 2 parts. Use UNION command to combine the core of the screw and the threads.
Then you can subtract the screw from the gear.
calebUYG4X
Observer
Observer
Yes, that makes sense.  Thanks.
