SubDMesh to STL
SubDMesh to STL
Ronald
SubDMesh to STL
Ronald
An STL file is not limited to manifold models, but AutoCAD requires a SubDMesh to be manifold; otherwise, it will not translate it. Can this not be resolved using a system variable so that all SubDMeshes can be translated?
BhaskarMurari
@Ronald there is currently no system variable in AutoCAD that overrides the manifold (watertight) requirement for SubDMesh objects during STL translation. This is a design limitation, not a configurable setting. You Use other Autodesk Applications such as 3ds Max to import the DWG and then Export to STL. 3ds Max is known to manage meshes and 3D Solid
autoid374ceb4990
Have you tried an online converter?
Can you post your drawing or the mesh file here?
What is the mesh file extension?
lauri_barnhart
Welcome to the community, @Ronald.
Hope you are well. Checking in to see if the information provided by BhaskarMurari helped clarify your question. If it did, please consider clicking on the 'Accept Solution' button. If you still need assistance, could you provide the information for the questions requested by autoid374ceb4990.
Lauri | Community Manager
