Stretch 2 Arrays
Stretch 2 Arrays
SilverlineWoods
Message 1 of 8
Stretch 2 Arrays
SilverlineWoods
Hi everyone. Using AutoCAD2025. Is there away to stretch two arrays at the same time where the intermittent one stays centered between the primary one? Attached is a sample of the panel I design. The bottom portion has weep holes spaced evenly between the drill holes. Since I have to change the panel size for each application, I would like to keep the drill holes 16" on center max with the weep holes centered in between. Any help will be very much appreciated!
Replies (7)
Message 2 of 8
Brock_Olly
Not sure if I understood 100% but I think this is what you meant?
There are ways to increase the amount of holes as well and have it fully parametric.
Message 3 of 8
SilverlineWoods
New attachment might help clarify. Panels range from 4" to 192" so I have to manually change the quantity of the drill layer (16" on center max) and manually center the weep layer. Wondering if there is a way to link the weep layer array so it stays centered between the drill layer array when I change the drill array quantity after stretching?
Message 4 of 8
j.palmeL29YX
Test the attached 1st attempt, if that meets your request.
Jürgen Palme
Message 5 of 8
Brock_Olly
I think it's possible without using constraints but it's for sure the best way to go here.
Sadly I don't have full autocad anymore
Message 6 of 8
SilverlineWoods
That's perfect! Thank you. Any chance you could give a brief explanation or guide me to something that could show me how this is done? Definitely want to use this in the future.
Message 7 of 8
j.palmeL29YX
... you could give a brief explanation
In the example above (post #4) I used two path arrays.
In the following video I used two (IMO more performant) rectangular arrays. The main principle in both is the same.
Correction
Error at 12:11   The Between value for the 2nd array must be "Step" (not Step/2). Sorry
If you have further questions, feel free to ask again.
Jürgen Palme
Message 8 of 8
SilverlineWoods
Really appreciate it! I will have to play around with it after I get some of these panels made.
