AutoCAD Forum
Strange Problem with Autocad file
4 REPLIES 4
john.hailey
423 Views, 4 Replies
Hey Folks I have a one of a kind (it seems) problem. Our Tech never seen it before and I haven't either.
Hopefully I can find a solution, (3 files from same model). Here goes:
I created a 3d model using CADWorx (an autocad shell program to make 3d piping model and drop iso's, uses isogen)
Dropped the iso drawings and worked on them. I notice some strange behaviour. Did a qsave and some of the colors changed.
Another time, part of the graphics disappeared. But here is the worst part, worked on them all day, saved it at end of day,
came back the next morning and I opened the file and it came up with a recovery, so I clicked ok, started to recover but when it was done it open
up and instead of having my 2d iso drawing it was the 3d model (a total saperate file and another folder that It was isogen from), the file was
now the 3d model. I even renamed the bak file and tried to open it and it did the same. Then I got the Autobackup file and it did the same.
I went to check to see the last saved date (check if tampered with) It showed I was last to save but the date didn't match the file details in the directory. That was odd also.
So I sent the iso files (before opening) to the tech so he could open the file (without having the 3d model file) and when he opened it, It did the exact same thing and there was the 3d model instead of the iso.
Side note: while working on the 3D piping, I made a (FBXImport) a Navis file. (FBX Export File). But, I brought it in a saperate 3d file and just exref in into
my primary 3D piping file. I'm wondering if thi sisn't the root problem.
Have anyone seen this before or have an answer?
4 REPLIES 4
wispoxy
in reply to: john.hailey
Takes too much time to locate the source of an issue like this. Better off doing a Factory Reset with AutoCAD. By-the-way, is the file a .dwg?
john.hailey
in reply to: wispoxy
Yes, it was a dwg file. (1) 3D model and (3) isometric piping drawings.
I'm wondering since the iso dwg was created through the isogen from the 3D model,
that possibly the drawings database retained the model it was made from at first and when the recovery
took place the prevous versions were corrupted, so it went all the way back to the first or original that was still embeded
in the drawing database and restored them with the 3D model.
Or, while I had both the 3D model open and the iso drawings open in the same session of Autocad, that
somehow the Autocad memory got crossed.
The laptop I'm using does have some graphics and ram problems that I've noticed. Maybe that also contributed.
That could be far fetched, I don't know. But, I deleted the 3D  model and pulled some saved copies of the iso's and I'm
re-working them.
I may never know the answer to this one.
Thanks for your reply.
dgorsman
ISOGEN doesn't work that way.  It takes a template file, copies it, and adds content to that file using the PCF file derived from the model contents.  The source model isn't directly involved in the process.  You should probably check your ISOGEN settings to ensure its reading the correct source file, and is writing to the correct location rather than the model location.
john.hailey
in reply to: dgorsman
Thats Interresting, I would like to learn more about how isogen generates the iso's. Maybe you could give me a link to read up on?
But as far as the settings, they're correct and no defferent from the many other times I have succesfully dropped iso's and issued the project drawings.
So, same question, model in another directory, Iso's in the Iso drawing directory, How could the drawing go into recovery and instead of your iso drawings showing back up, it is now the 3D model you generated the Iso's from?
AutoCAD Inside the Factory
