Strange display behaviour
peterm
Message 1 of 16
peterm
This odd behaviour has just started since I got a new larger monitor.
At the bottom of the screen there is a two line space, indicated by the red arrows.
When I finish a command and press enter, the two line space briefly changes to one line and then back to two.
This causes the main workspace to flicker as it resizes which is very annoying.
Any ideas what may be causing this?
Replies (15)
Message 2 of 16
user181
If you right click on the model or any paper tab and select the "Dock inline with status bar" option does it fix the problem?
Message 3 of 16
peterm
That sounded like a good solution.
However, when I do that, it does go down to one line, but as soon as I click in the drawing area, it reverts back to two lines.
Message 4 of 16
peterm
I wonder if the problem has anything to do with the fact that my new monitor is 4K.
Message 5 of 16
marianne.franken
same problem overhere, I have not found a definite solution yet but I manage it (for now) with:
options-display- layout elements -
then turn off : display layout and model tabs.
Message 6 of 16
marianne.franken
I just found 'the problem maker'
If you turn OFF dynamic Input and Infer Constraints (this because they are both the trigger) you  will experience a silent screen 😀
Message 7 of 16
pendean
Community Legend
Community Legend
Nice tip.
Message 8 of 16
marianne.franken
i meant not only turn it off but also not showing in the statusbar (? i do not know for sure if that is the right name)
Message 9 of 16
peterm
Well, not sure what happened.
I turned off the model and layout tabs yesterday and continued to work.
This morning I launched AutoCAD, opened up a template and turned on the model and layout tabs to test Marianne's theory.
For some strange reason the tabs are now in line with the status bar and the problem has gone away.
Thanks for all the suggestions. I'll let you know if it starts happening again.
Message 10 of 16
peterm
Looks like I spoke too soon. It's back.
I already have Dynamic Input and Infer Constraints turned off and not showing.
I'll try and find a bit of time to experiment with what makes it come and go.
Message 11 of 16
Alfred.NESWADBA
what happens if you set STATUSBARAUTOWRAP to OFF?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 12 of 16
peterm
Hi Alfred,
That seems to have done the trick. Thank you.
That's a bit of an obscure setting. Where did you come across it?
Message 13 of 16
Alfred.NESWADBA
With the growing status bar there was an issue that the screen started blinking ... everytime when the status bar splitted from one row to two rows, then back to one and so on (continuous).
Then Autodesk introduced this flag (as hidden system variable) which blocked the splitting.
(you'll find more if you search this forum for this system variable if you want to know more about the history)
- alfred -
Alfred NESWADBA
Message 14 of 16
peterm
I wonder why it was behaving like that when, in my case, there is clearly no conflict between the layout tabs and the status bar.
Message 15 of 16
Alfred.NESWADBA
Maybe new issue with high resolution displays. But I don't know that, sorry.
- alfred -
Alfred NESWADBA
Message 16 of 16
Pointdump
Alfred,
Well that's a new one! It's not in System Variables, it doesn't auto-complete in the command line, and it doesn't use a (1) or (0) for on or off.
Thanks for today's learning moment.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
